Design forum
Ecodesigner air-to-air energy recovery + ground insulation
I'm constantly using Ecodesigner and found that the air-to-air energyrecovery is not working properly. Whether you input 50 ot 90 for a recovery percentage, the outcome is still the same.
the other issue is when using floors on ground - no matter how thick is the insulation, the calculation result is still the same. Wierd, huh?
I'm using still Archicad 12. Could that be the trouble?
The air-to-air energyrecovery should be working in AC 13 EcoDesigner. The other stuff I don't know.
uploaded the file, but couldnt reply to from inbox.. tried several times but got such error:
Could not connect to smtp host : 10060 : A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
DEBUG MODE
Line : 114
File : smtp.php
so.. if u people from graphisoft read this, I've uploaded the troublesome file.. Although i think the problem exists in all of my files
I had this same problem in the last two days.
But it rarely happens, could not really get it consistently.
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
Didn't find the answer? Start a new discussion
Labels
