Design forum
Edit Surface Texture
so_pbg
Howdy, it's been a while! Apologies in advance...
I used AC10 quite a bit, and am slowly getting back into it, this time with AC19.
Can't seem to figure out how to access/edit a texture PNG/JPG/etc to have it display in the 3d window (it renders fine after changing the surface color). I imagine there must be a way to do this?
With AC10 I would copy the PNG file, edit it in photoshop, then save as a new png/jpg in the appropriate library folder.
Any thoughts/links/etc much appreciated.
AC 19 (9001)
Win 10 x64
1 ACCEPTED SOLUTION
Solution
Read about the Embedded Library.
You need to add the texture's image file to the Embedded Library. Then you will be able to set the image for the Texture of the Surface of your choice.
Laszlo Nagy, Lead Moderator, Community Admin
AMD Ryzen 1700X CPU, 48 GB RAM, NVidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
2 REPLIES 2
Solution
so_pbg
Awesome totally worked! Thanks LaszloNagy - you rock!
AC 19 (9001)
Win 10 x64
Didn't find the answer? Start a new discussion
Labels
