It is just like any other object - you can open it by name so long as you can remember what is was called (and where).
Otherwise you can use the 'Select object by subtype' command.
It may not be in you menus if it has not been included in the Work Environment but you should find it in the GDL toolbar.
You will still need to know the name although it may be easier to spot if you don't and it will also show you all the objects using that sub-type.
