Edit dropdown box using 2D Dynamic Hotspot
JGoode
I've come across an object that has a dropdown box that you can select using a dynamic hotspot.
I was just wondering how you could do this?
Here's a link to the gif of it in use.
http://www.masterscript.nl/WebRoot/StoreNL2/Shops/78066077/MediaGallery/Total_Keynote/SelectKeynoteName.gif
Thanks
ArchiCAD 23
Windows 10
4 REPLIES 4
the parameter has to be defined with values{2} with corresponding text strings.
If the hotspot has to be not movable - but changing the parameter by it - it has to be put as a "reference parameter"
Piotr
JGoode
Thanks Piotr, interesting!
How would you use this script to do for example, if *parameter* = "Select value 1" then *do this* ?
ArchiCAD 23
Windows 10
just plainly if... then
of course GLOB_MODPAR_NAME can be used as well with it
In the example I have placed the way that the hotspot will go back to default (the other parameters is changed)
Piotr
Nader Belal
Mentor
@jGoode Thank you a ton
And for that person that created that script
