Licensing
About all sorts of licenses, their management, Graphisoft ID, Graphisoft Store, License Manager Tool, etc.
Edu version to commercial version
How do I convert AC 18 Edu to commercial version ?
11 REPLIES 11
I don't have an EDU version so I cannot try.
But you should try exporting attributes in the Attribute Manager into an AAT file or XML file, then import it into the commercial version.
That might work.
stefan
EDU version is fully compatible, but files (PLN) saved in the EDU version are permanently marked.
Attributes are transferrable.
I don't see why GDL objects wouldn't also work.
If you upgrade to Commercial, you could request a one-time conversion of your project files to a commercial file, so you can re-use your work.
Archicad27/Revit2023/Rhino8/Unity/Solibri/Zoom
MBP2023:14"M2MAX/Sonoma+Win11
Archicad-user since 1998
my Archicad Book
