Design forum
Elements not showing in section view
CYNZ
I am having an issue with elements not showing in section view. All the solutions provided in posts I have see don't seem to fix the issue.
I have checked:
Renovation filters
Layer combinations
Any ideas?
Thanks
6 REPLIES 6
Lee Hankins
Mentor
Which elements aren't showing? Have you checked Model View Options? Which version of Archicad are you using and on which OS?
Lee Hankins
ArchiCAD 4.5 - Archicad 26UKI Apple Silicon 4032
macOS Ventura (13.2)
CYNZ
I'm using Archicad 24 student edition - Windows 11 Pro (21H2)
Its a number of elements - Columns, stairs, plumbing fittings, some exterior walls
I have checked the model views and they seem ok.
Please see attached the floor plan and the section incase they help in any way.
Lee Hankins
Mentor
Have you tried turning all layers on to visible. I know you mentioned you had checked layer combinations but it would be worth a try. It would be useful to post some screenshots of the section, the section settings and a 3D view to see if the elements appear there.
Lee Hankins
Lee Hankins
Mentor
Is the section set to zero depth in the section settings? If it is try setting it to infinite or set depth.
Lee Hankins
ksjhawk
Any chance you'd be willing to share the model? It does look like a zero depth section. You may be right Lee.
MacBook Pro Apple M1 Max 64GB ram
OS X 12.4
AC26 - AC6.5
Didn't find the answer? Start a new discussion
