Exporting and importing object parameters
Pato99
I have a range of electrical objects (+50), each time I make an addition I need to add a parameter manually. I wish there was a way to export that parameter or all parameters as an xml then import them into the next object along with it's values.
Versions 10 to 27
Metabox Prime-X P775DM2-G (Clevo),
GTX 1060 6GB GDDR5 VRAM - G-Sync,
i7-6700K (8M Cache up to 4.2 GHz),
32GB DDR4 2133MHZ,
512GB SATA 3 M.2 SSD,
Win 11 64
David Maudlin
PatHarding88:
What you should do is create your own Subtype for your electrical objects. Parameters in this Subtype will appear in all child objects of the Subtype (in blue). If some of the parameters are not used in particle Objects, then they can be hidden and removed from parameter transfer.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
If You exported the library to xml You can of course copy the parameters section between objects...but subtype is the easiest way.
Best Regards,
Piotr
