LaszloNagy wrote:
And set that bigger screen to a higher resolution so you will have more pixels vertically to fit all those open Settings Dialog panels.
Mahmoud may not need a higher resolution if he gets a bigger screen.
Just using 100% scaling will make more fit on the screen.
What resolution are you running Mahmoud?
I would recommend no less than 1920 x 1080.
I run this on my laptop which has around a 15-16 inch screen.
It is usable but a little small to see.
So I have a larger 27 inch screen I connect to at home.
At that same resolution (that is as high as my laptop/screen will go to), it is all a little bit too big.
I am used to working on a 24 inch screen at work which is better.
