Favorites DIMENSIONS
Does any one have a system for recording the commonly used dimensions or notes. Like the favorites system. There is so much math to use AC10 well that I often find myself spending lots of time just to find out what was a dimension or..?...that I used several days ago.
Thanks
4 REPLIES 4
I have used both favorites and modules to save settings for all sorts of annotations for reuse and transfer between files. Both will work but I find I prefer the modules. If you are referring to the dimension preferences (ie. units and accuracy), these are saved with the views and not in the favorites or modules.
WOW!
This is something that I never got in all the classes that I have addended. Many thanks.
However, it looks more complicate potentially than what I had in mind, but useful if I can just unravel it with my slow e-mind. All the Modules, Modulele Master Layer, Place Module, Module Management, Nested Modules options....again a WOW! I guess nothing is as simple as it might have appeared.
Many thanks
Modules aren't really that complicated. Perhaps I could come in to give you a quick tutorial when I am in the city sometime.
Link
For notes, you can simply create an indpendent detail called NOTES, put all your notes in it, then open this detail window and drag'n'drop your notes onto the floor plan/SE's etc.
This can form part of your standard CAD Template.
Link.
