papsphilip wrote:
how can i make sure for each favorite folder i have, that the contained elements will load in the appropriate layer.
Each element was in the correct layer when i saved it as a favorite
The favourite folders do not contain any settings (i.e. layer).
It is each individual favourite that does, which you can right click and 'Edit' at any time.
papsphilip wrote:
Where are the favorite preferences?
The favourite settings can be found here …
Check the 'Element transfer settings'.
The one marked as default should have the 'Layer" option ticked so it is included, otherwise the layer will be ignored.
Also you can right click on a favourite and choose the transfer setting you want to use, so you can use any one other than the default.
But it is easiest to set the default as you want so you don't have to keep choosing the transfer setting you want (or keep changing which one is default).
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
