Fill wrap without exploding a wall
Hi !
That long pattern lines in circle are horrible. I tried to depict pattern I want to have inside a bottom wall.
Is there a chance to do fill wrap into a curved wall and keep wall as wall element, being able to insert door windows etc.. ?
Podolsky
Ace
Yes, you can achieve that. First you need to have symbol fill (symbol fill is made from lines and arcs that you can paste from floor plan). In Building Materials settings choose 'Fit to skin' for fill orientation.
And - this is important part - you need to create composite structure wall if you want that this function would work. It can be just one skin composite.
Podolsky
Ace
Thanks for explanation it works like a charm now, pattern creation is little bit complicated but wrap is good.
