Fills show through text
Hello -
I have put some fills on my floor plan to indicate different flooring patterns. I am just using "simple drafting fills" On my text I have set to have an opaque background. This shows shows properly in ArchiCAD, however, when I import it into Plotmaker 9 the opaque backgrounds go away and the fills show through the text. It does not matter if I have used "The Text Tool" or "The Label Tool" I get the same results.
Any and all help with this situation is gladly appreciated.
Thanks and best regards - Chris
Check your PM display options. The 'Fill Background Color' should be set to 'By Element Settings'.
This setting controls the display of all fill backgrounds; fills, text, labels, etc.
James Murray
Archicad 25 • Rill Architects • macOS • OnLand.info
Thank You!! I read the help files, the forums, and tried so many things and I never stumbled upon that needed setting.
Cheers - Chris
