Find existing program path from registry
hamenkiakehna
How do I find the path of an existing program, so that I can add some more files to one of its directories?
The program has the registry information under:
SOFTWARE\GRAPHISOFT SE\Archicad 22\
The following code does not work for me:
#define PATH ReadReg(HKEY_LOCAL_MACHINE, "SOFTWARE\GRAPHISOFT SE\Archicad 22\")
DefaultDirName={#PATH}
1 REPLY 1
Hello hamenkiakehna,
Archicad is available on 2 operating systems.
Perhaps you should tell which one you are talking to get a better answer ?
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
