Fire doors must have a frame underneath. How would you describe it?
LeeJaeYoung
In Korea, fire doors must have a frame underneath. How would you describe it?
This is the best I can do.
AC27 on window 11
4 REPLIES 4
Would a sill give better options for you to be able to display it correctly or even both a sill and a threshold?
Lee Hankins
ArchiCAD 4.5 - Archicad 27UKI Apple Silicon 27.2.0
macOS Sonoma (14.4.1)
LeeJaeYoung
sill and threshold are not frames.
And sill cannot be in the same position as the threshold.
I would appreciate it if you could tell me a little bit longer.
I didn't understand your intention with translate.google.com.
I'm afraid my answer is wrong.
AC27 on window 11
Lingwisyer
Guru
You cannot get the profile with standard Archicad doors, but you can use a double sided threshold with 0.01 extensions and it will look pretty close.
Ling.
thank you
This method doesn't seem to be the way I want it to be.
AC27 on window 11
