2017-08-2911:54 PM - last edited on 2023-05-2602:15 PM by Rubia Torres
My Fit In Window command all of a sudden zooms out my window to
0.000000%. No matter how I try to tweet it, it goes to 0%. I have to use Zoom to Home to adjust my zoom. All other AC functions work with no problem.
Is there anything I can do to set this back?
Ben Ling
B.L.LING ARCHITECT INC.
Vancouver, BC, Canada
Then I would say what most likely has happened, is there is an element widely scattered from the rest of your model. If, at full extent, you do a select all, you may notice two different groups of hotspots. This should enable you to identify which element/s have gone rogue...
