2008-12-14 02:19 AM
2008-12-14 11:01 AM
rocorona wrote:Good catch, Roberto. The Library Developer kit documents 100's of gs_ parameters for particular object subtypes... but within the page for each subtype (e.g., windows). I do not see a 'master' listing anywhere.
... the gs_ui_current_page parameter ...
But this is not in the list. The list only contains parameters starting with "ac_". Is there another page for "gs_" parameters?
If you want to use the Previous and Next buttons, too, you should add a integer parameter to your object, gs_ui_current_page. The execution environment (i.e. ArchiCAD) will set this parameter's value when the classic Previous or Next button is pushed.Oddly, the online file link calls these the "GDL Technical Standards 2.0" (for version 10). The downloadable document in the 12 lib kit simply calls them the "GDL Technical Standards".
Example showing the whole mechanism:
2008-12-15 12:55 AM
