If you want to change the reveal side of an existing door and you want to keep the door swing in exactly the same location you have two choices.
ALT click the door to get all of it's properties, delete the existing and place a new door.
You will have to re-do any associated dimensions.
Or select the existing door, flip, rotate and mirror it.
It will be exactly the same swing but with the reveal on the opposite side.
the dimensions should stay associated as well.
