2021-11-13 05:44 PM
Hello All,
Beginner questions:
Attached are images.
Two floors have different composite spec but the top layer is the same. On plan it leads to a line (yellow circle), misleading for site crew.
How can we avoid this line? I have tried solid operation connect, it didn't work.
Thanking you
Kind Regards
pb
Solved! Go to Solution.
2021-11-13 06:09 PM
In "Model View Options" under "CONSTRUCTION ELEMENT OPTIONS" change the "Slab" option to "Eliminate".
Subject | Likes |
5 | |
4 | |
3 | |
3 | |
3 |
