derekjackson wrote:
Hi, in some large projects we can end with 40+ worksheets, referencing all sorts of info. It would be really helpful to be able to group them, or organise them in subfolders much like you can do with Layouts.
It sounds like you're either not understanding the difference between the Project Map (first Navigator tab) and the View Map (second tab) ... or you are using a Clone folder for your Worksheets.
The Project Map is grouped by viewpoints. All worksheets will be grouped together, as they are the same type of view.
If you clone that folder, then indeed, you will see all worksheets grouped together in your View Map. Personally (and this is my personal preference) - I NEVER use clone folders because they never organize by views the way I want. Even with Stories, there are stories that I do not want in my View Map.
Simply create whatever folders you want in your View Map and drag your Worksheets viewpoints into them (with the appropriate View settings defined). The easiest way to do this organization is to not use the pop-up or the docked Navigator, but instead to use the double-paneled Organizer palette, which lets you see two tabs of the Navigator at the same time:
https://helpcenter.graphisoft.com/user-guide/76325/
PS Just checked out your site - awesome matte painting / illustration! The best I've ever seen in this community.
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
