Design forum
Formatting A Parameter Script to include a Single Quote 1&qu
I am writing a GDL object that will have a parameter script for common text string choices from a pull down.
i.e.
!!MAIN TEXT
values "MainText" "2x6", "2x8", "2x10", "2x12", "14 TJI 560", custom
The question is how to actually include a single quote in the text string without confusing the syntax of the code?
It would be preferable for the output to be 2"x6" rather than 2x6.
Thanks,
JFA
2 REPLIES 2
James Murray
Mentor
jfa_ra wrote:
i.e.
!!MAIN TEXT
Use a different kind of quotation mark; the single (apostrophe) and the little retrograde accent mark (`) will both work.
VALUES 'MainText' '2"x6"', '2"x8"', ...
A bit OT, I would find 2"x8" to be potentially confusing since it should be a nominal dimension. We wouldn't use the inch sign unless it was a true dim. But you should stick with what you and your contractors are accustomed to.
James Murray
Archicad 25 • Rill Architects • macOS • OnLand.info
Cool! Thank you. That was easy.
jfa
Didn't find the answer? Start a new discussion
