Apart from horizontal or vertical lines or rectangles, not that I know of.
You will have to use a picture.
And be aware that the bounding box of the picture will block other infields & outfields even if the picture has a transparent background.
It is especially troublesome for infields - it may look like it is in front of the picture but you can type anything in the field.
The trick I have found if you want an infield and picture to overlap is to script the infield, then the picture and then the same infield again.
UI_INFIELD...
UI_PICTURE...
UI_INFIELD...
