Not directly with just a GDL object.
You could place an object but you would have to stretch its nodes manually.
An add-on could be written though that would use the co-ordinates from a fill and create the object shape using thoes co-ordinates.
The "slab accessories" are an example of this.
They get the co-ordinates of a selected slab an apply an object to the perimeter (a footing for example).
So if you can create your own add-ons or you know someone that can (I can't) then you could be on to a winner.
