Parametric design
About Rhino & Grasshopper and PARAM-O.
GH-AC Live Connection 1.7 cannot run in ARCHICAD 20 6005.
GH-AC Live Connection 1.7 (20.0.5034) cannot run in ARCHICAD 20 6005. (TAI)
5 REPLIES 5
It doesn't run for me either - on the Mac version. This is annoying because I couldn't even launch AC5025USA. I did a clean install which worked, patched to 5025 and the crash on launch came back. Decided to patch to 6005. ArchiCAD started. On installing 6005, the Add-On Manager reports that the Grasshopper Connection is outdated.
Has anyone been able to get this to work? If so, how did you do it.
Think Like a Spec Writer
AC4.55 through 27 / USA AC27-4060 USA
Rhino 8 Mac
MacOS 14.2.1
the same here on windows 10.
In the add on manager of Archicad it is written that the plug in is outdated...
Please fix it .
regards
Postby anna » Tue May 23, 2017 9:33 pm
Hello,
thank you for reporting this! The ARCHICAD 20 Build 6005 will require the update of the Grasshopper connection too. (If you now check the Plug-In in the Add-On Manager, it will state that the file is outdated and the Add-On cannot be used with this ARCHICAD version.) The Build 6005 can currently be reached only as a Preview because we are still testing it before releasing it as an official Update. The newer Grasshopper Plug-In, which is required by this Build will be released on our site together with the official Update.
Sorry for your inconveniences and thank you for the patience!
Graphisoft quietly released a version of the Connection tool compatible with AC20 build 6005. Not sure why they don't announce these on their beta forum, but it's now available.
Rhino 8 Mac
MacOS 14.2.1
Link to announcement post and download link:
http://archicad-talk.graphisoft.com/viewtopic.php?p=268201#268201
One of the forum moderators
AC 27 USA and earlier   •   macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Learn and get certified!
