GLOB_CONTEXT in interactive schedule
Frank Beister
I try to add a symbol view of an object in the interactive shedule. But it has to be different (more simple) than in floor plan.
I don't find a way to separate the runnings of the script for floor plan and for interactive schedule.
In 2D-Script GLOB_CONTEXT and GOB_SCRIPT_TYPE are always 2. In 3D-Script they are in the shedule 5 - in 3D-window 3.
I don't know why. Is this a double bug? Does it nor make a sense to differ between this environments / contexts?
P.S. I have tried a few other GLOBALs to find a third bug to use as characteristic. No success.
2 REPLIES 2
Miquel Garcia
I have exactly the same problem. I can control different appearances for 3D views and Section/Elevation windows with GLOB_CONTEXT=3 and GLOB_CONTEXT=4 in the 3D Script but I'm not able to use any other index.
I want opening lines for my own doors in the Schedule, but not on elevations, the workaround for me is:
IF Glob_Context<>3 OR Glob_Context<>4 THEN …
I hope this can help you. Anyone knows a better way to do it?
Miquel
Capella & Garcia Arquitectura
AC18 - AC21, iMac 27" 3.1 Ghz Intel Core i7, 16GB Ram, OSX 10.13.1
Frank Beister
There is a bug in the interactive shedules. Maybe this here is another effect according to this bug. This information I got from GS. They have it in the track, but I don't know, when they fix it.
I solved it by a 3d side projection which I control by IF GLOB_CONTEXT=5. Unfortionatly TEXT does not work in shedules. So I had to use a vector font.
I think anytime GLOB_CONTEXT will return 6 and all will be good. 😉
Learn and get certified!
