Gap in the stair
mrco
Hello everyone
I am new in this forum, I would like to ask for your help. I have this small problem
I don´t know but the stair has a gap in section, do you know how I can fix it?
thanks a lot in advance for your help.
Marco
2 ACCEPTED SOLUTIONS
Emre Senoglu
this should fix it: https://capture.dropbox.com/MbI63eP5yNNDy2lt
AC26 ARM // MBP M2 Max // Twinmotion | Corona | Rhino
www.senoglu.dk
not a very 'neat' solution but it does fix your problem:
https://capture.dropbox.com/zrntxNqPCiADfLwb
www.senoglu.dk
8 REPLIES 8
Emre Senoglu
www.senoglu.dk
It worked perfectly thank you Emre! now that we are chatting do you know how to solve this issue? I would like that the stair rest will be the same line with the stair steps, becuause there is a gap, unfortunately the "landing options are in 0" so I really don+´t know how to change it, so in case you know I will really appreciate your help, thank you so much in advance
can't really think of a direct solution, but if you care to share your file - or perhaps a file with just that stair - i can (and perhaps others as well) take a look.
www.senoglu.dk
Thanks Emre
sure no problem, how can I send the file?
Hi Emre
here is the file with the stair, hopefully it is possible to solve the problem
thank you very much in advance
Marco
www.senoglu.dk
mrco
thanks a lot for the solution Emre!
all the best!
we could also change the reference line to the inner part
