2019-10-05 02:44 PM
Solved! Go to Solution.
2022-04-14 09:39 AM
Hi Jorge.
Hi Marius
I have the same problem on M1 Max.
Have you solved this issue?
2022-04-19 10:09 AM
Hi! @Mario Sacco @ArkMW
some anonymous help coming from GS local support send me this:
If you have a brand new mac, and install Rhino 7 only, there was a bug in the GHAC that refers to the wrong Plist file.
To solve the issue, we need to navigate to
/Users/<username>/Library/Preferences/
then rename the PLIST: "com.mcneel.rhinoceros.7.plist"
to: "com.mcneel.rhinoceros.plist"
Please note that the Library folder inside userhome is a hidden folder. You can follow this guide to access it:
https://www.lifewire.com/os-x-is-hiding-your-library-folder-2260833
hope this can help!
2022-04-19 10:27 AM
It works!
Thanks a lot!
Marius
2022-04-19 10:41 AM
It works.
Both in AC24 and AC25. I just tested only few components.
Thank you @jorgebeneitez
2022-04-19 03:32 PM
Great!! Glad it helped
2022-04-19 04:49 PM
Amazing! Thanks @jorgebeneitez for your answer! I tested it and seems to work for me! Great! I was quite disappointed with Archicad support/ Graphisoft, which was saying to wait for an eventual update with AC26... Quite nice that it can be solved very easily! 😄
2022-04-22 04:33 AM
Thanks! It works for me!!!
Ruy.
2022-05-27 05:41 AM
Thanks for the support Jorge but in my case doesn't work, rename the file avoiding the ".7" but still no objects showing neither in AC or Rhino, besides when renaming the preferences file, a new com.mcneel.rhinoceros.7.plist file get created in same place just when closing Rhino or starting Rhino no matter what, there's always the 2 files, the one with the ".7" and the renamed without it.
Do you know any other solution please?
Regards.
2022-05-27 05:46 AM
I forgot to mention, I'm in AC25-3011, Rhino 7 and MBP M1 max..
Is there a way to avoid creating the com.mcneel.rhinoceros.7.plist file automatically each time I close or start the app? maybe that can solve it I think.
2022-09-13 09:28 PM
I've been having this problem and as you say, starting Rhino Grasshopper creates a new...7.plist file. Will have to try complete uninstall reinstall for both AC25 and Rhino 7.
Subject | Likes |
5 | |
4 | |
3 | |
3 | |
3 |
