Design forum
Grasshopper Rhino7 does not reference AC 25 Geometry
sondermann
Hello,
I have connected my AC project with Grasshopper successfully. However, Grasshopper won't reference AC Geometry.
E.g. when trying to set one AC Morph in a Grasshopper AC Morph Parameter component (Rightclick-menu) Grasshopper/Rhino3D won't switch over to AC to allow me picking a Morph.
I act exactly like in older versions where everything worked properly.
I can tell both AC and GH are connected properly because the GH AC-component doesn't show up red.
I use AC 25 INT Edu with Rhino7 Grasshopper on Mac (Big Sur 11.6), each running the newest version available.
Any hints why this doesn't work are highly appreciated.
Best, Horst
Best regards, Horst
ARCHICAD 22 4023 INT EDU
Rhino3D V6 SR10 / Grasshopper 1.0.0007
Windows 10
3 REPLIES 3
Minh Nguyen
Graphisoft Moderator
Dear Horst,
Thank you very much for the question and I am very sorry for the experience!
If I may ask, if you drop an Input component into the Grasshopper canvas while the connection is made, and right-click for selecting, does it open up a menu like this?
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Hi Nguyen,
no, this does not open, although the connection is seemingly running.
Best regards, Horst
Best regards, Horst
Windows 10
Minh Nguyen
Dear Horst,
Thank you very much for the confirmation!
I would like to ask for your help with this one. Our developer created a special add-on for the investigation. I will reach out to you for further intruction.
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
Didn't find the answer? Start a new discussion
Labels
