2021-11-14 09:50 PM
HELP!
I am trying to import a Sketch Up model into Archicad however it does not fully import all of the objects/buildings and I cannot work out why it is doing this. I am importing via File>Interoperability>Merge>Merge from file...
I am working on a MAC PC and running Sketch Up + Archicad on Student licences.
Screenshots attached.
Any help would be gratefully appreciated. Thank you.
2021-11-15 12:41 PM
Hello oliviajane,
Did you try to open your skp file directly by open a new projet into Archicad ?
Is there a difference ?
2021-11-18 03:14 PM
Hey Chrisophe,
Thanks for your reply.
No, there is no difference. If I directly open the skp file as a a new project, I get the same unfinished model imported.
2021-11-18 03:15 PM
Hello oliviajane,
Did you try to explode you skp model : no more group or component ?
2021-11-18 03:22 PM
@oliviajane Did you search these forums first for solutions? It is important to spell things correctly: SketchUp is one word, not two...
Subject | Likes |
5 | |
4 | |
3 | |
3 | |
3 |
