HOTSPOT on Elevation View
hgodhani98
All of a sudden I am seeing several hotspots on Railings and Beams on my Elevation. It did not appear before, so I am guessing I might have accidentally changed a setting. Can someone help? I am attaching a screenshot of the elevation
Chris Grantham
It looks to me like you may have inadvertently deleted the source view and are now left with an independent elevation view.  If the elevation in the project map no longer says "Auto-rebuild model", but rather "Independent" that is what happened and you are left with a collection of lines and fills.
16" MacBook Pro M1 Max
Mac OS 12.2.1
ArchiCAD 25 Build 6005
Chris Grantham
Mac OS 12.2.1
hgodhani98
That makes sense Chris. I was a bit impatient and created new views which fixed the issue. But after your explanation, I now know the reason.
Thank You
