Handrail connection issues - U shaped stair with 2 landings
artktecture
I have a U-shaped stair that starts on the main floor with a flight to a landing, then a riser to another landing, and a another flight that ends at the second floor. The railing is associative and for the life of me I can't get the handrail connection at the U to connect properly. It also display incorrectly in the plan view. I need it to run continuously from main floor to second floor.
Any ideas?
artKtecture uses Archicad 24/Twinmotion
Lenovo Thinkpad | Xeon E2176M@2.70 GHz | 32GB | Quadro P4200 8GB
Oculus Rift S VR tours
Contour Rollermouse Red Plus (ditch your mouse and get one of these!)
Using a highly modified Shoegnome template (Thanks Shoegnome!)
1 REPLY 1
Podolsky
Ace
I rather prefer to use non-associative (static) railing to use for the stair - just to avoid such situations, when ArchiCAD by default cannot figure out needed connection.
