Head Casing Overhang -- Wall Closure Type Discrepancy
I am working on setting our company favorites and am having an issue with the Casing feature in the W1 Casement 19 Window (and presumably other window types as well).
We typically spec a 1" Head Casing Overhang on the outside. This option is available when wall closure is set to "Stud Wall", but when I select the "Stud Wall with Siding" option, and go back to Casing options, the option for an exterior head overhang is greyed out. Does anyone have a solution?
3 REPLIES 3
Just ran across your post. I am having the same problem. The only solution I could come up with was to just leave the wall type to plain stud wall. If I change it to stud wall with siding, my overhang disappears and it is grayed out. Guess its just a bug........
genarch
This problem still exists in AC 20. Does anyone know if the INT library has the same problem? I'm curious about the differences between INT and USA libraries, but I don't know how to get ahold of the INT library to check it out. My AC electronic delivery link goes straight to the USA version.
Mac OSX 13.6.5
AC27&26, Artlantis 2020, TwinMotion
iMac Pro 2017 / 8-core 3.2 GHz / 32GB RAM
Lingwisyer
Guru
The INT library uses a completely different set of doors. I do not recall there being a siding option for them.
Changing the country code in the URL does not work?
Ling.
Learn and get certified!
