Help please...Files won't Open
Hi all,
I had inadvertently deleted some work files that hadn't been backed up and needed to go to a computer tech to try and recover them. The problem is that ArchiCAD won't open them, even with 'Open & repair selected file' as it then says that it cannot be open and gives the option to 'Open as Read-Only' but then says that the 'Repair process failed' and "Cannot read Plan file.'
Does anyone have any suggestions as to how I can get it open? The file shows that it has 69MB so it's there, I just can't get to it. I've been on the phone to tech support but they couldn't do anything.
thanks for any help.
kind regards,
Gabrielle
If they have been recovered then they may not be the complete file - I guess there is nothing that you can do about that.
But if you deleted them can I ask the obvious - did you look in the re-cycle bin?
If you have a Codemeter key then remove it before you look in the re-cycle bin as otherwise it may appear empty.
This is on a Windows PC at least.
Thanks Barry,
yes the first thing I did was 'Restore all items' which I was then told was not a good thing to do as it re-writes on the SSD. I didn't think to take out the codemeter, but when I do it now, it's not showing anything more. I had my hard drive and the files on there before I got the SSD, so I have everything on there up to mid Sept, but not since. I know, I should have backed it up earlier but just got lazy I suppose, but in amongst ISP problems getting a Laptop up and running and no sleep, I was going to back up the file on an external hard drive and thought that instead of going through all the 'merge folder' problems and the time it takes, I just thought that I'd delete it off the external HD and just do a clean copy, but deleted the file off my computer instead! It's one of those stupid mistakes that my computer guy didn't set me up with a proper back up programme before now.
My only hope is to try and open the corrupt file I think, or do the work all over again.
Hi Gabrielle, Have you had any luck to restore your files? or you lost them?
