Help with Quoin
Srinivas
I need to model this window, please see the attached image.
Thank you for all your help,
Srinivas.
ArchiCAD Services
ArchiCAD since v9 to latest
iMac, Windows 10
if the windows are all the same i would use morph to add the quoin to a simple window, if you have several windows with different dimensions and you will use it often i would use gdl.
Srinivas
There are Several windows of different sizes, it seems Morph is the only way to go, as I couldn't find the object that does this easily. Thanks for your help.
-Srinivas
ArchiCAD Services
iMac, Windows 10
