Help with fixing some text position
matleonii
Hey guys, this is the first GDL object I've made and it pretty much worked fine, except for this thing:
I need this 3d object to have a specific 2d representation(it the object to represent electrical fixtures in the plan view), in which each part of it should have a text associated with it.
I've made it in a way that it was possible to move the text around, so that I could position it in the best spot it the plan view and that it would stay in the proportional position in different scales.
I worked fine(as in the fist row of the image)! BUT only as soon as I rotate the object it messed with everything(the second row). The image bellow will show what I mean.
This is the code I used for each one of the texts (1,2 and 3):
! Text Rotation - Readable / Always Horizontal / Align with Symbol
r = request ("View_Rotangle", "", _angleViewRot)
! Actual rotation of the 2D symbol:
_totalRotate	= (SYMB_ROTANGLE + _angleViewRot) MOD 360
! Count the number of transformations of the
! coordinate system in different cases
_nTrans = 0
if iTypeTextRotation = 2 then					! Readable
    if (_totalRotate > (90 + EPS) & _totalRotate < (270 + EPS)) then
        rot2 180
        _nTrans = _nTrans + 1
    endif
else
    if iTypeTextRotation = 1 then				! Horizontal
        rot2 _totalRotate * (SYMB_MIRRORED - not(SYMB_MIRRORED))
    endif
endif
! Text Position - USING "GLOB_SCALE/50" TO MAKE POSITION THE SAME ON ALL SCALES
! THE "/50" IS BECAUSE I WAS DRAWING ON THE 1:50 SCALE AND NEEDED THING TO BE ON THAT PROPORTIONS
ADD2 0.06*GLOB_SCALE/50, 0.13*GLOB_SCALE/50
! MOVABLE HOTSPOTS
unID=1
!_________________________moving it horizontally
hotspot2 0,verti2,unID,horz2,1+128 : unID=unID+1
hotspot2 -1,verti2,unID,horz2,3 : unID=unID+1
hotspot2 horz2,verti2,unID,horz2,2+256 : unID=unID+1
!_________________________moving it vertically
hotspot2 horz2,0,unID,verti2,1+128 : unID=unID+1
hotspot2 horz2,-1,unID,verti2,3 : unID=unID+1
hotspot2 horz2,verti2,unID,verti2,2+256 : unID=unID+1
DEL 1
! TEXT ITSELF
TEXT2 horz2+0.05*GLOB_SCALE/50,verti2+0.1*GLOB_SCALE/50,txti2
! Delete transformation after Text Rotation
del _nTrans
Is that a way of getting it right, even when I rotate the object. It is probably something silly, as this is my first GDL project.
Thanks for the time folks! hope some of you can help me with this.
1 REPLY 1
matleonii
Just something that i thing is important info to find this solution.
When I rotate the object the text remains on the exact same position. I then need to move it to where I want (in this case the position on the original image of the post).
