A '.PLA' file is not a library that you can load but is a PLN file that contains the library saved with it at the time - an archive file.
You open it just like any other PLN file - the only problem is that version 20 can only open file back to version 10.
So you will need an earlier version or a file convertor to open and save it to version 10 which you can then open in 20.
File convertor link ...
http://www.graphisoft.com/downloads/fileconverter.html
But you may not need to do this if you say you already have the library?
Unless there is something specific in the file you need (i.e. it is a template).
The library should be the same though.
Version 20 can't read a version 8 file directly but it can load a version 8 library.
No guarantee that the library parts will work properly though as some aspects of GDL have changed over the years.
