Horizontal and Vertical Ribbed Wall Panels
Eric Milberger
OK trying to narrow this down to a narrow solution
I have multiple use for horizontal and vertical ribbed, corrugated and smooth panels
The smooth is east.  Just a material though it does not include the skin thickness
A horizontal I can create in the Wall assembly
Little time consuming but the sections are even better than the Wall assembly as I end out with a metal skin on hte entire panel.  And also some of the flashing
It is the vertical panels I have issue with.  I want to keep them walls so that I can place doors and windows with ease.
And overall I’d prefer one solution that would allow me to rotate the material.  And result in a good section.
Eric Milberger, Architect | Master Planner
My free coverings will likely do what you need. you can also use custom profiles in the coverings if the basics ive included arent whats needed.
link in my signature.
Lingwisyer
Guru
There was also Hmooslechner's accessory.
https://community.graphisoft.com/t5/Design-forum/GDL-for-Wall-accessories-addon-using-profiles/td-p/...
Also, which version did you code in Seneca?
Currently v24
