2022-05-13 04:26 AM - edited 2022-05-13 04:28 AM
Hello Archicad-people!
Is it normal, that Revit geometry, coming from the built-in RVT plugin is not solid in Archicad?
I mean I can see only the shell. Faces only. Revit geometry is hotlinked.
2022-05-13 06:45 AM
Hello Sergueï K_,
I also saw the same case. Could it be related to the type of modeling used by revit ? Revit would use surface modeling like sketchup modeler ?
