Hotspot Elevation
Guru
Hello all,
Does anyone know how you can modify the elevation of a Hotspot?
Plugins such as ArchiTerra convert imported DXF files into point levels represented in ArchiCAD as Hotspots. These are then selected using a Fill as a boundary to create a Mesh. This would imply that the Hotspots contain elevations data?
The woes of elevating a 2D contour plan with next to no level references...
Ling.
If you mean the hotspots created by the Hotspot tool, those are 2D-only and contain no 3D information.
There was another thread a good 2 years ago, where people wanted to input 3D points from Archicad into Grasshopper.
I wrote a simple GDL script which I named "3D Point". You can find it here:
https://archicad-talk.graphisoft.com/viewtopic.php?t=59883#p281578
Guru
The Hotspots are created by the plugin. Once created, you can interact with them the same as any other Hotspot you may have placed with the Hotspot Tool. Probably a question for the plugin devs in regards to how they translate the imported .dxf
Ling.
