How -To, hide empty openings in schedules
This item was addressed in ac7 by allowing items assigned to a specific ID to not show in schedules. It worked great for hiding empty door or window openings on the schedules. Is there any way to do this in version 8.1 ?
4 REPLIES 4
Same thing. Just assign a special ID (I use "xxx", but use whatever) ... and in the interactive scheduler, add a criterion that says all ID's not equal to that value.
One of the forum moderators
The problem is that You cannot exclude multiple ID's
but You can add multiple ID's...
So when I had some complicated situation lately - I had to add ID's one by one...
Regards
Piotr
Hi Piotr,
I agree that that is a problem - GS doesn't let us specify the criteria with much generality. (We can say the ID is x or is y or is z ad infinitum, but cannot say the ID is NOT x and NOT y etc.) Something for the wish list!
BUT, GS allows us to test for prefixes and suffixes which I think takes care of things adequately, unless you cannot make your ID assignment work with it.
For example, I made a sample file with some doors, with the IDs D01, XX and YY - with D01 (D02, etc.) being the "real" doors that I want in the schedule and XX, YY and for that matter, any door or opening that doesn't start with D being something to be excluded. The criteria is very simple and shown in the screen shot below - note the use of the prefix operator saying to include only those ID's that start with "D".
Hope that helps,
David Larrew
We've always used blank " " IDs for non-scheduled openings. Refer to my earlier related post:
http://archicad-talk.graphisoft.com/viewtopic.php?p=2994&highlight=#2994
David Larrew, AIA, GDLA, GSRC
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
