How can I copy an image to ArchiCAD and paste it on floors?
Hello! I’m currently working on a school project that requires me to place a complicated drawing on the floor (like a floor pattern) and walls (like a mural) and I cannot find a way to do it. It’s basically just a painting on the floor/wall and I already have the image with a transparent background, and what I want is to paste the image on the floor in a way that allows me to resize it and move it around as I see fit, in a way that’s visible on the floorplan and also 3D. I say transparent background because I need the floor underneath to show in some empty spaces on the image. Thank you for any help you can give me!
alemanda
A solution is to create a bitmap fill
AC 19 and AC21 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
David Maudlin
Dua Kramer:
For seeing the image in 3D, you can use the Carpet 21 object (horizontal) and the Painting 21 object (vertical); use the Custom Picture option and enter the name of your image that must be in the loaded libraries. To add an image to the floor plan, use the Figure Tool, and check the "Transparent" option.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
For the 3D also a Morph with no thickness can be used. In this case it will be like an extruded L. Morph let you align the 3D texture the way you need it.
