2022-04-17 05:05 AM - edited 2022-04-17 05:09 AM
Hey guys , I found a problem. How can I mirror an Object and a morph on Z axis? Thank you.
Solved! Go to Solution.
2022-04-18 04:36 AM - edited 2022-04-18 04:40 AM
but I can't mirror morph in the elevation/section. When I use mirror and click in the elevation/section view, it always mirrored left and right, not up and down (Z axis)
Or only I can do is mirror it in the same elevation and rotate the new one 180° and move it up to the original one??
2022-04-17 11:20 PM
For objects it depends but for morph on the other hand you can go to 3d view and mirror from there or you can create an elevation/ section view then mirror from there. 😎
2022-04-18 06:33 PM
surprisingly you can't mirror a morph you can only rotate and mirror it then bring back to the same location or your preferred axis point. 😐
2022-04-19 06:13 AM - edited 2022-04-19 06:21 AM
yeah, I can't make it. Can you show me a GIF or some op videos. I use mirror function, and want to drag a mirror line, when I first click the view, they mirrored side by side.
2022-04-19 06:46 PM
2022-04-19 07:36 PM
OK, Thank you for your reply. So you can't mirror morph on z axis directly either, haha. I am balanced.😁
