How to / Advise / Ideas to model roadway transitions
Rakela Raul
Where I have a problem is on the roadway transitions I.E. The roadway has 1 slope to the right and a 2nd slope to the left, so, what put this same road together is a piece called 'transition', which is a 'twisting' element that goes from a negative to a zero and then to a positive slope and 'join' the 2 parts of the roadway. (an element similar to an windmill blade)..but, an element that carry parapets, marking, lightpole, etc.
In the past I used ac11 and maxonform to 'twist' elements...now i am on version 12 with no maxonform.
sorry for long post...and please i need ways / approach from you pros to model this.......huge thanks in advance
the original drawing will come in a dgn format
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
6 REPLIES 6
Ralph Wessel's "Objective" add-on might do what you want.
Rakela Raul
thanku Matthew, i had tried objective before but didnt do it.
Peter and Dwight helped me out before on something similar or the same
(i always run into the same problem it seems) and the mesh tool was the most flexible ....i can always go back to 11 and MF
or do some shopping @ OO
Ralph Wessel
Mentor
The latest version of OBJECTiVE (but not released yet) has new properties for profiled objects to twist them around a specified angle - an example image is attached showing a rectangular cross-section twisted through 20 degrees along its length. I can send a beta version to you if you want to try this.
Ralph Wessel BArch
Rakela Raul
Great news Ralph !!!
I would love to try it out.....you already know my contact info since we have objective:
raul rakela / beiswenger, hoch & associates, inc.
thanku vmuch Ralph and congrats, great addon
Rakela Raul
this OBJECTIVE tool should come STANDARD in Archicad.......thanks again Ralph and all.
Attched a quick test
lets hope Graphisoft do that. This would be a HUGE ASSET to the next release...
