If you snap to something, it should set the same storey as that element.
Basically, it automatically sets the storey based on the height at which you place the element.
If you don't want to snap to an existing element, but you have another element of the type you are placing, then ALT-click that existing element to get its settings.
This will set the height and the storey, but also all the other settings (size, material, etc).
If you don't want to do that then before you place the element, open the element settings and change the height there to the appropriate height above project zero.
For some reason that doesn't work if you change it in the info box or change the 'z' height in the co-ordinates palette - at least that is not working for me.
I find you have to do it in the element settings.
