How to Use GDL Debugger with graphical interface
Nader Belal
Mentor
Hi there,
I would like to know how can I use the GDL debugger to track the changes that start by pulsing a custom UI_button and the implicated changes it does in the Parameter script.
Thank you in advance
A good friend of mine have once told me that I´m so brute that I´m capable of creating a GDL script capable of creating GDLs.
Sam Karli
I'm afraid that GDL debugger is not maintained for a long time, at least I simply couldn't manage to start it properly (at least in ACSE 2016).
Its doc states that it can be run only in 2D/3d/Parameter context so an UI context seems to be out of its scope.
http://gdl.graphisoft.com/tips-and-tricks/how-to-use-the-gdl-debugger
GDL/Python/C++ dev
Sam Karli
GDL/Python/C++ dev
Nader Belal
Mentor
Thank you Sam
leceta
The joy of working in GDL...
