SOLVED!
How to control the Furniture door fill in elevation
How to control the fill on furniture door in elevation view. I use object - Kitchen Cabinets 24. The fill on doors appears turned at 90°. How can I control fill direction?
1 ACCEPTED SOLUTION
Solution
It seems the cabinet is using the material rotated from its intended direction.
I am not familiar with that object so do not know if there is an option to rotate the material or maybe it is a custom door panel.
If you can't control it in the object, then you could duplicate that material and rotate the fill.
Then use the duplicate material in the cabinet.
3 REPLIES 3
Solution
I have been test this situation on different object. The situation on different object is different. Then is necessary to have two the same fill rotated at 90°.
vdentello
The quickest solution would be so.
But seems like there´s an inconsistency in Texture mapping, hope they'll fix that. They shouldn't be rotated.
Archicad User Since 2013
GDL Developer
Experimenting with API
from Brazil
Learn and get certified!
