How to create Wall End from Wall End Tool?
Hello Guys,
I am wondering how do I create wall end from the wall end tool on archicad 17. I understand that there is a GDL form for this but it kept ending up in Object tool when I created the wall end that should be ending up in Wall End Tool. How do I put that in Wall End Tool instead of Object Tool? Anyone know about this? Any helpful hints or suggestion for me, let me know.
Thanks!!
3 REPLIES 3
Do you mean you created your own GDL wall end object?
If so then you need to set its subtype to 'Wall End'.
There is a 'Subtype' button in the Details section of the GDL editor.
Hello Barry,
Yes, that is correct. I did not know about subtype part as I am learning the new process with GDL. Yes, I went back to opening the Object that I created and changed to Subtype to Wall End as you said. Apparently, it did not appear on the wall end tool. I wonder if I did something wrong or missed the step.
David Maudlin
cadpg:
Two things to try:
1. Save the library part after changing the subtype.
2. Reload Libraries before trying to access the part with the Wall End Tool.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC27 USA • iMac 27" 4.0GHz Quad-core i7 OSX11 | 24 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
Learn and get certified!
