In version 23 (haven't checked earlier versions) there is a command to enable the saving of surfaces.
It can also be found here …
This will add a little "Save" button to the surface palette and will allow you to save individual surfaces as a GSM file.
Otherwise there is a command (again in 23 at least) that allows you to "Save All Surfaces as GSM".
You will need to go into your Work Environment and add this command to a menu.
I don't see it in any of the default Work Environments.
This will allow you to save ALL surfaces at the same time (this can take a little while and you will se no progress bar).
