How to create wireframe & white model?
cadsph
When in elevation or plan view(s) - how do you control  the way the model is shown i.e.
how to show model in wireframe or white or coloured etc...?
I've changed the reno - filters and model is shown in the following ways (please see attached).
I don't understand why 3D view options only apply to 3D views (not 2D)?
LeeJaeYoung
Do you have any questions about this?
AC27 on window 11
LeeJaeYoung
AC27 on window 11
cadsph
HI,
Thanks for that. But it's not possible to have wireframe in 2D view, or do we set it transparent?
Another question: what does "Cover Fill" control. Please see attached.
HI,
==> I can't understand your work.
       I do not use wireframe even in 3D....
       I only use transparency to make the inside of the glass invisible for drawing.
I don't use this feature either.
==> Please refer to this YouTube explanation
Archicad 25 New Feature! Section Settings Deep Dive - YouTube
AC27 on window 11
