How to cut out pieces of a roof or slab
Espen da Silva
Hi, I have made an object using the roof tool (selected below) that I would like to cut out a piece of along the dotted line as shown:
Aditionally, I want to cut the same object at the bottom along the dotted line as shown here:
I wasn't able to find a consistent workflow to make this happen, is there a simple solution for this?
DGSketcher
Legend
Convert to Morph and edit as required. Or use SEO and again convert to Morph so it displays correctly on plan.
1 REPLY 1
DGSketcher
Legend
