Howdy gents. My search returned this old thread as the closest to my current dilemma. I’m trying to figure out the best way to place markers that will display top of wall elevations in plan. I don’t care what tool is used to generate these but would like to have them linked to specific walls. It appears that the Level Dimension tool is out since gravity does not work with walls
An Object based marker cannot be associated to another element AFAIK, so that leaves the Label tool. Is this a correct assessment? If so, can someone please point me in the direction of the proper code to transfer parameters from the wall to the label. Thanks.
Regards,
Geoff Briggs
DeForest Architects
Seattle, USA
AC25 INT, Mac (home), Win10 (work)
Yes, you read that correctly, we are in the US but use the INT version, because the libraries are better.
